TwinTurbo.NET: Nissan 300ZX forum - Re: 300zx cutting out above 5700 RPM. Help!
MaxxAction
on September 17, 2012 at 7:15 PM
posted by Fatal
on September 17, 2012 at 04:43 PM
Boost leak....
Fatal
16:43:16 09/17/12
Re: 300zx cutting out above 5700 RPM. Help! -
MaxxAction
19:15:11 09/17/12
Re: Re: 300zx cutting out above 5700 RPM. Help!
Fatal
19:28:07 09/17/12
Re: Re: Re: 300zx cutting out above 5700 RPM. Help!
MaxxAction
20:51:10 09/17/12
Re: Re: Re: Re: 300zx cutting out above 5700 RPM. Help!
Fatal
22:43:47 09/17/12
Re: Re: Re: Re: Re: 300zx cutting out above 5700 RPM. Help!
MaxxAction
06:22:16 09/18/12
When did it start? When's the last time you changed plugs? (n/m)
JDAVE
07:37:46 09/18/12
Re: When did it start? When's the last time you changed plugs?
Fatal
05:35:41 09/20/12
Is this happening any lower rpm ever? Do you have a wind....
craigz96tt
09:58:18 09/18/12
Re: Is this happening any lower rpm ever? Do you have a wind....
Fatal
05:44:06 09/20/12
Re: Re: Is this happening any lower rpm ever? Do you have a wind....
craigz96tt
10:47:21 09/21/12
have you verified you fuel pressure under load?
aliaZ
12:13:55 09/18/12
PTU connectors?
Rocket man
19:38:58 09/18/12
Re: PTU connectors?
Fatal
05:53:51 09/20/12
MAF, PTU, CAS, Plugs, plug gap, boost leak, injectors (n/m)
Summeronthechain (MN)
20:31:26 09/18/12
Re: MAF, PTU, CAS, Plugs, plug gap, boost leak, injectors
Fatal
07:07:41 09/20/12
Re: Re: MAF, PTU, CAS, Plugs, plug gap, boost leak, injectors
MaxxAction
17:47:24 09/20/12
Re: Re: Re: MAF, PTU, CAS, Plugs, plug gap, boost leak, injectors
Fatal
17:08:17 09/24/12
